I am doing some research on the gsr swaps...and was a little confused on the ecu part....(noob)....Someone told me that the best ecu for this swap is the p28 chipped...so i started looking into that and came across this site (hyperducktuning) on which it states as follows
" Can I run a P28/P08 on a GSR (B18C1) or SR-V (H22A)?
Yes the ecu will run fairly well but should only be used for RACE applications. As they do not control IAB (Dual Stage Intakes) and loss of bottom end torque will be the result."
I am not looking for a complete race setup...my car would be a daily driver so no race applications....but would like to run it once in a while....
so here are the questions
what is an IAB (dual stage intakes)
What setups are you guys running
What would you recommend
Any help on this would be greatly appreciated...
khiz
khiz
