Stroker?
Discussion in 'Engine Building' started by 1sikef, May 6, 2009.
  1. 1sikef
    1sikef New Member
    I just got a deal on a eagle stroker kit for a b16 (1.6L to 2.0L) with high compression pistons and knife edged crank, it will be going in a jdm b16a block with type-r oil pump/ water pump ect. the head is a jdm b16 head with ctr internals, buddyclub cam gears, skunk 2 intake mani/ with blox tb and megan racing header, im just wondering if anyone has a similar set up with a stoker kit and can tell me the hp range there making
  2. red91efhatch
    red91efhatch New Member
    Albuquerque
    depending on elevation, on an n/a build expect 160/200 depending on elevation maybe a tad more, big gains would be felt if adding f/i
