strut bars
Discussion in 'Accord' started by ludecrasy87, Feb 23, 2007.
  1. ludecrasy87
    ludecrasy87 New Member
    wats up
    i need help i dont know if i need to jack the car up?
    Like im tryin to install these strut bars into my car i know its only removin 3 nuts then just place them over and crew back on, But do i need to worry if the screw falls off
  2. hondaburner95
    hondaburner95 Banned
    va
    im not sure what your talking about screws falling off?? when putting on the tower bars front or rear you dont have to jack up the car. take the three bolts off put the bracket over the studs and put the bolts back on .DONE . well dont forget to adjust strut bar tight as you can get it then tighten the lock nuts
  3. hondaburner95
    va
    also if you saw a screw fall off then you got a broken stud
  4. BrutalB83
    Rochester Hills, MI
    How would the bolts fall off?? Strut tower bars bolt to the top of the struts, so if your car isn't jacked up, then there's practically no way that those bolts are going to drop down.
    You should be using a torque wrench to tighten the nuts down though, there's a specific torque that they're supposed to be tightened down to.
