stupid question
Discussion in 'HYBRID -> BA-BB /CA-CD' started by DesertNightEagle, Jun 15, 2005.
  1. DesertNightEagle
    DesertNightEagle Senior Member
    Perryville, MD
    Is the intake manifold bolt pattern on a 93-96 h22 different than 97+? If they were the same, what halts someone with a 93-96 h22 lude putting on a Jackson Racing SC? Same thing with 97+ SH and non SH models, what's the difference that they need 2 different models?
  2. reikoshea
    Dallas, TX
    I think it may be a clearance issue or maybe pully design. Might wanna ask the people at JR if you are curious.
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Yep, it's clearance between the manifold and firewall. It's smaller on the 92-96's.
  4. 92civicb18b1
    92civicb18b1 The Trisexual
    Just get a M62, make a custom lower manifold (A lot easier than it sounds) for it and run the charge pipes similar to a turbo setup. Mount it above the exhaust manifold and make some really good heat sheilds. just don't plan on checking your oil level...ever unless you remove the blower.
  5. DesertNightEagle
    Perryville, MD
    ehhh, thats ok. it was just an idea, although looking at pictures of it, i still think it would fit... oh well, i guess i'll just have to my turbo (which i already have) instead. hmmm, i'll post pictures of someones engine with it on and then mine and see if you guys think it would work.
  6. DesertNightEagle
    Perryville, MD
    You have reached your bandwidth limit and can not view this image.
    WHAT!!! what type of garbage is this?? lol .... ahh damn, well i was going to show 2 pictures. I guess i'll just have to wait
  7. DesertNightEagle
    Perryville, MD
    I've heard of it being done but I've no details regarding anyone's
    success or failure. Space (or the lack off it) has always been the
    issue with the '96 & earlier body-style Prelude. A second inhibiting
    factor is the lower section of the original intake manifold [which is
    re-used] on an early car is different than the later one and that also
    has to be swapped.
    Other considerations are brake master cylinder and the top of the shock
    tower assembly. I have heard those two things do interfere and that the
    motor must be 're-angled' in order to get clearance. We do not suggest
    attempting this conversion.
    Thank you for emailing. K T
    Keith S. Taber - Technical Support Specialist
    Jackson Racing Specialty Products/Moss Motors, LTD.
    888-888-4079/Direct(805)679-7019/FAX(805)692-2525
    keith@jacksonracing.com / taberk@mossmotors.com
    M-F 8am > 4:30pm PDT/PST No weekends/holidays
    Email: SEAL_Reaver@hotmail.com
    Saw, your supercharger kit for 97-01 Prelude, why doesn't it work with
    older H22 models? Is it about space in the engine compartment or is the
    bolt pattern different on the intake manifold? If it's space,can you
    give me a box dimensions the roots blower and the intake manifold?
  8. driver1
    driver1 Senior Member
    with the turbo setup you already have why are u even considering a jackson charger????
    Makes no sense
  9. DesertNightEagle
    Perryville, MD
    ehh, i just wanted to know why it couldnt be done for future references
  10. DesertNightEagle
    Perryville, MD
    haha i can view pictures again!!!!!!
    anyways, i think it would work, but i wouldnt exactly know unless i had the stock intake manifold which i dont have anymore
    oh well, you're right, i like my turbo setup too much. too be exact, i really like how the intake manifold looks compared to the roots blower sitting there taking up all the space.
    man.... i just need to hurry up and get my car running so i can put on that turbo. Hrmmm too bad i'll be in the Army when it's all done.
  11. driver1
    who makes that mani u have? i like it...and it appears to be ac and ps compatible
  12. DesertNightEagle
    Perryville, MD
    turbo or intake? turbo is maxrev, intake is golden eagle (which is basically the same as STR)
  13. driver1
    i meant the turbo mani,......what u have to give for it?
