subframe reinforcement brace...
Discussion in 'Wheels / Suspension / Tires / Brakes' started by scottp11, Sep 3, 2005.
  1. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    I was wondering if anyone has used this? It looks very sturdy and stiff. Check it out :D
  2. ryangt
    ryangt Senior Member
    yeah i have one on my 01 ex. Its from progress tho, and i would never install a sway bar without one again. Take a little work to put on, IE you have to drill a coupld holes and thread those holes, but over all VERY WORTH IT.
  3. scottp11
    Thanks man, anyone else?
  4. phunky.buddha
    Dallas / Fort Worth, TX
    If you start researching about using ITR rear sway bars on Civics and Integras, you'll see tons of people talking about combining rear subframe braces like these with large rear sway bars. If you're going to go larger than 17mm in the rear, I would consider a brace like this a must-have.
  5. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    beaks for awile now with no problems....check my signature
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    $174? Geez, I'm going to make a few of these.
