Not moving when you hit the switch? Remove the switch, take it apart, clean up the contacts, and put it back. Should work like a champ. I had to do that on mine, and its a common problem in CRXs.
i all ready did that, but i got a new switch.... ive got power at the switch, power at the moter, and iwas able to open and shut it using 12v( car battery)when i hook it up to the harness,,,,,, thanks
