K2e2vin Senior Member Jan 27, 2006 #1 I have GSR rods, one has a little spot of surface rust. Is it still ok to run these?
S smooth_criminal Senior Member Jan 27, 2006 #2 As long as it's only suface rust, Clean it of and it will be fine, After cleaning if you notice any dimpling in the metal it's junk.
S StealthMode Kung Foolin' Jan 27, 2006 #4 That's something you don't want to mess with, because if that rod is damaged, it will go straight through your block.
reckedracing TTIWWOP VIP Jan 27, 2006 #5 where is the rust on the rod? if its on the top or bottom were any bearing would ride then i would get it machined...
K2e2vin Senior Member Jan 27, 2006 #6 its on the middle of the rod where it says P72. Thanks for the help and suggestion guys; I took it to a machine shop(T-Hoff for those wondering) and they said its fine.
