suspension for auto x experts
Discussion in 'Wheels / Suspension / Tires / Brakes' started by 97hatch, Jul 23, 2007.
  1. 97hatch
    97hatch ?
    Anderson IN
    ok well after drag racing for so long i wanted to get in to something else so i went to my first auto x this weekend loved it but i have some issues that i would like some help on this is my setup
    tires falken azenis on delsol wheels
    NEX full coil over suspension
    tie bars up and lower front and back
    and a ls vtec
    and this is all in my ek hatch
    ok im pretty good at suspension setup (at least i think)
    i got the car level all the way around when i measure to the jack points
    this is how i got it setup the measure ments are on the wheel
    in the front i have
    camber 0.250 measured top to botom (not center to top)
    toed out .187 total not per side so 1/6 per side
    0 turns of pre load
    tire presure 30psi
    rear
    camber is close to zero
    toed in less than a 1/6 close to zero
    4.5 turns of preload
    tire pressure 48psi
    ok my problem is i was not able to keep the car from pushing (understeer) any help cant run less air in the front when i marked the tires they roled over almost perfectly. is there any one that makes caster adujsters for a EK i would love to have some but cant find them looked all day as i know that more caster would help lots
    well any help would be great
  2. LSCRX
    LSCRX New Member
    97 Hatch....you said you had NEX coilovers? the GT or the SS? do you like them? I am trying to get some feedback on em. I am also looking to getting into auto x, and want a decent suspension. But i also like to go on weekend drives up the mountains.....so they need to work :D
  3. 97hatch
    97hatch ?
    Anderson IN
    im only runing 30 psi because every one advised me to keep lowering it as to how far over the tire rolled does any one know of wher i can get some thing to adjust the caster on the front i would really like to add some caster to it.
  4. 97hatch
    97hatch ?
    Anderson IN
    also i have the ss and the are very stiff but they work pretty good if i did it again i would buy some good adujstable shocks and good coil over kit
  5. eg6sir
    if i did my suspension again, id buy some PIC Apex this time
  6. 97hatch
    97hatch ?
    Anderson IN
    well i have actually never played forza and what little i know about suspension setup comes from my gocart experience and do you really think that 30 psi is way to low for a car that weighs nothing and im not causing roll over so it should be ok
  7. pissedoffsol
    azenis sidewalls are so stiff, that they don't really roll over like a normal street tire does.
    30 is too low and 48 is too high.
    you'll probably find more comfort at 36/34.
    understeer is caused a lot by driving error.
    slow in, fast out.
    brake before the turn and just leading in with a little left foot trail braking to get the ass-end happy. then be on the gas through the corner and on the way out.
    caster is not your issue.
    Wheel Alignment A Short Course
  8. 97hatch
    97hatch ?
    Anderson IN
    thanks b i had the rear so high as i was trying to ret it to rotate better and it did help i will try raising pressure this weekend when i go out. yes i know slow before the turn and acelerate out. ok enuff with the tire pressure and DOES ANY ONE know where i can get a caster kit for a EK.
