Suspension Swap
B-SERIES_BOY
This is probably a common sense question but just making sure. Will suspension components from a 92-95 civic fit and support a 94+ integra? Springs/shocks, sway bars, strut bars, upper strut mounts. I'm replacing my eg sedan with an integra sedan. Also will the weight difference be too much for the springs and shocks?
Thanks for the reply. I figured the spring rates would be off. Is it safer getting springs specifically for the integra? Everything is brand new. I built complete spring/shock combo so I could just replace them in the civc but never got the chance.
Also since I have all brand new upper strut mounts, bushings, bumpstops, etc, will all of that be integra spec? Also will the front lower fork and rear lca bolt up? I have ST dropped forks and lca's. They lower the car 1.5" without altering the geomtry and are rear camber adjustable.
Thanks again...
