Swap Guides
Discussion in 'HYBRID -> EG-EK / DC' started by red1HB, Apr 4, 2003.
  1. red1HB
    red1HB Junior Member
    i need to know how to swap a b16 or b18 into my 93 hatch dx... also, is there a way to tell if a del sol is vtec from the out side?? :worthy:
  2. E_SolSi
    if it has hub caps its an S (SOHC non-VTEC)
    if it has stock rims its either an Si (SOHC VTEC) or a VTEC (DOHC VTEC)
    if it has rear disk brakes its either an Si or a VTEC
    if you can see the tachometer look at the redline... S = 6800, Si = 7200, VTEC = 8200
