Originally posted by xlerate93@Aug 6 2003, 12:46 AM
It's a 99 JDM B20B, LS Skunk2 IM. That dirty hose right against the thick one, its right under the first intake plenum runner.........
Where does it go?
Originally posted by darwins_vtech@Aug 7 2003, 08:26 AM
if it is a coolant hose, then it has to connect the the block or head somewhere. OR do you meant that it is coming out of the head- or block, then there should be a spot on the firewall that it should connect to.
Darin
Originally posted by rsaeini+Aug 7 2003, 02:43 PM-->darwins_vtech@Aug 7 2003, 08:26 AM
Darin
why would you connect a collant line to the firewall?
:ufucktard:
