dang civic
Member
I got a 93 si and im putting in a 00 si motor. I have a few issues which i didnt expected. One, the 93 wiring harness has everything the motor needs, minus one connector coming from the 00 motor. I think its the knock sensor, at the back of the block, behind the alternator. The wires comes from the oil pan area. The 93 wiring harness doesnt have a connector for it. If im correct as to what it is, since im using the p28, it doesn't look for the knock sensor rite? Second. I cant use my throttle body cable from the 93? which do i use? the 00 si tbc?
