swap problems
Discussion in 'Civic and CRX - EF' started by twistedobsessionz, Oct 18, 2011.
  1. twistedobsessionz
    twistedobsessionz New Member
    ok i bought a running 91 crx si d16b1 for parts car even drove it home it was wrecked... well yesterday i bought a nice 91 crx si with a d15b7 the guy did a hack job on the engine harness.... i swapped my other harness in and like 3 plugs dont match, any insite?
  2. twistedobsessionz
    ment d15b1 my bad
  3. Rammus
    Rammus New Member
    MN
    If I remember correctly a D15B1 is OBD0 and a D15B7 is OBD1.
  4. monotech
    monotech Member
    Are your plans to stay OBD-0 or go OBD-1? I can make you the proper harness you need if you plan on going OBD-1 and I also have jumper harnesses available for OBD-0 to OBD-1 changeover.
