SWAP QUESTIONS PLEASE HELP!!!
car wont start
i hear fuel pumping around the entire system so i knnow it's not fuel
could it be the injectors?
i disconnected one and turned the key twice - one of the pins on the injectors showed voltage with a test light, the other little pin didn't...
does that mean something?
what else could it be?
i was told if timing was off by anything it wont start?
compression seems fine. fuel (as i said) is fine.
spark plugs are in the right order..
pretty sure everything is grounded fine
all the points on my main relay are showing voltage with a test light except for the pin that goes to A7..
according to my diagram, A7 shows FPR. Can anyone confirm this?
What is FPR.....fuel pressure regulator?
ANy ideas?
car was a dual carb civic converted to efi with d15b engine
vss is yet to be connected., same with CEL but i'm sure that wont affect startup
UPDATE:
i checked each spark plug lead and i'm definately getting spark
my timing is off by about 1 or 2 cm and i was told that this shouldn't affect startup..
check the fuel and thats flowing fine..
wat could it be?
is there anything else i should check with the test light?
what sensors will affect startup?
any help would really be appreciated....
