ok guys i need help this is what i have its going into a 94 eg hatch b18a1 block(bored .030 over new pistons rings rod and main bearings) gsr head(complete intake,dist,etc.) b16 tranny crankcase breather kit Ls motor mounts vtec controler clutch/flywheel axels belts gaskets gsr oil pump p72 comp gsr wiring harness if you cant tell already im kinda new at this import stuff im i missing anything ?what hoses do i need?is this gonna be fast?
