Swap
Discussion in 'HYBRID -> EG-EK / DC' started by ad daddy69, Apr 14, 2003.
  1. ad daddy69
    ad daddy69 Junior Member
    i have an acura integra 91 and i was wondering what u would suggest for an engine swap on it. I was thinking of doing the ls/vtec or the b18c. any suggestions?
  2. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    how about the B17...
  3. ad daddy69
    how much do the b17s run for
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    IF,you can find one I would think they would go for about the same as a newer B16,maybe more.
  5. ad daddy69
    i was thinkin towars a b16, gsr or type r engine im askin what ones to u think will easily be tuned and cheaper to do? also which is the easiest and cheapest to drop?
  6. pissedoffsol
    b18a is the cheapest and easiest cuz it comes with a cable tranny, not hydrolic
    obd1 b18c1 is expesive and a little trickier and you still need a cable tranny
    b1c5 is much more difficult and you still need a cable tranny
    b16 is torquless
  7. ad daddy69
    i want to swap a type r but what all will i need to buy and what do u think the total cost will be with everything
  8. xj0hnx
    C.C.TX.
    He already has a B18A1 :huh:
  9. ekPhred
    ekPhred Senior Member
    since you already have an ls motor, why not build the motor up a bit (ie: bottom end) and go lsvtec? just a suggestion.
  10. ad daddy69
    i was gonna go ls/vtec but then i was thinkin that would end up costin around 3500 and for only about 1 or 2 more i could get a type r. but how much do u think the ls/vtec would cost me?
