Accordturbo94
Hey what happens if you dont. swap the:
ECT switch A: This will need to be extended to the thermostat housing on the passengers side of the back of the head. The ECT sensor and ECT sending unit fit fine (under the distributor.)
*NOTE: There is no ECT switch B on the JDM H22, just spare back the connector.
Also I have one more question. When you guys did the h22 swap in your car did your car originaly have vtec. If so.. did you have to add to the vtec oil pressure plug? I thought the solenoid and pressure plug came out at the same place.. but they really dont. the plug was way back by my thermostat! and the solenoid plug was right at the solenoid. I have no idea what the extra plug that comes out at the solenoid plug goes to? Make sense? please try to make the best of it.. lol
