swapping ew4 - d15
Discussion in 'Civic and CRX - EW' started by crx-505, Dec 3, 2008.
  1. crx-505
    crx-505 New Member
    Hi i am just wondering how hard of a swap this would be . i am interested in doing this cause my ew4 has quite a bit of miles on it . And i can get a d15 for rather cheap . how much needs to be done . ie wiring ? computer? ect ... and what if i were to put a d16 with v tec?
    thanks sparks
  2. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    Well, you know that thing called google?? JK i was in the same boat a while back, but never did the swap. ... had a 84 civic hatch with ew1. I did some research and found that you could (if you want to) keep the EW bottom end and swap a d15 head and ecu, fuel lines, etc. no problem. Well, im not entirely sure if thats true seeing as i didnt even end up doing the swap... but i do know that a head gasket for EW1 will work for D15. Look it up man, and if you decide to tackle it, please document the build. Good luck man.
  3. crx-505
    crx-505 New Member
    thanks for the input ... can anyone else confirm this .. any one actually done it ? that sounds like a interesting way to do it
  4. cjvictoria
    N. Chuck, SC
    you may need to get the more experienced member's attention...
  5. D15Beater
    D15Beater HNFTuning
    Concord N.C.
