swapping the b18a or b18b into the hatch
Slammed90Lude
i check the reference and swap sections and while the descriptions there were very helpful i've still got some questions- I picked up a PR4 ecu and i was going to use that to run the motor i drop into my 92 dx hatch- can i use this ecu for either b18a or b18b? why or why not- also what mounts will i need to buy- i know that the b series all bolt right in to the 5th gen civic but do i need rear mount bracket or whatever it is? also will the linkage that Hasport sells for these swaps work ? any info would be great- thanks guys
obd0 ecu can't power obd1/2 electronics, and vice versa. you need to match the dizzy/alt/injectors to the ecu.
motors are NOT obd. electronics are.
stock 94+ teg mounts are what you need.
the rear mount you speak of is for 6th gens.
linkage- 94+ teg
So if I'm droppin in a 97 ls into my 98 hatchback, I need a rear mount? Where do I get this rear mount, is it the mount from the 99-00 SI?
