sway bars
i have a 94 ferio. i have put on the itr rear lower control arms and shocks. but i need to know if the oem rear sway bar brackets will bolt on to the itr control arms. i would like to put on a rear sway bar. ferios sway like an airplane.
okay IIRC to run the ITR bar you're going to need a subframe brace. ASR or beaks.
check your lower control arms for holes that are not related to ABS, toward the outside by the shocks area. dont have them? you will need either EX/Si or GSR lower control arms to fit the bar on properly.
yeah, and i drive a mirage and its not a b16 swap.
for shits and giggles this is a 21mm ITR bar on my mirage before it tore out the trunk since i didnt bother bracing it.
i went and bought a sway bar from the junk yard with the brackets. bolted right up to the itr rear lower controls arms. coolness. thanx
