System Draining my battery!?!?!?!?!!!
Discussion in 'Car Audio / Security / Electronic Accessories' started by Bl6CRX, Dec 26, 2003.
  1. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    alright, well about six months ago my system started draining my battery, so when I would park for the night, i would take the amp wire off the battery and everything would be fine, well after i but the b20 in, i hooked it back up and it was fine for about a month and kniow its doing it again!!! I know its not that battery, ( I changed it) and my alternator was fine when i had it checked the first time it was draining, so any ideas/experience with this???
  2. brntorangehatch
    brntorangehatch Member
    is the amp always on???
  3. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    check the amps wiring... you may have the "b+" and "remote" wires hooked up wrong.
    The b+ should be connected directly to your batteries positive post
    And the remote should be connected to a 12 volt source that turns on when your RADIO is turned on. Most radios come with a wire built into their harness that is to be used in conjunction with an amp. This wire provides the "remote" power source when the radio is on.
  4. Bl6CRX
    UCLA
    no only when the car is on
  5. Bl6CRX
    UCLA
    just checked it, there right, thanks for the idea though!
  6. Prowler
    Prowler Super Moderator
    B MT
    do you have underdrive pulleys? do you have a capacitor? some things to consider.
  7. Jshade
    Jshade People are strange
    Springfield Missouri
    get a multimeter, and check what the parasitic draw is, then when you find out what the draw is start disconnecting things . it could be as simple as the interior light or it could be the amp. when you disconnect something if it doesn't take the draw away then hook it back up. when you lose the draw then youve found the problem. <_<
