saturn_boy96
88 C1V1C 53D4N DR1V3R
i think with this turbo i should be able to hit around 280 crank hp at 15 lbs. the block should will have new bearings, arp rod bolts, arp head studs, new rings, new seals. i don't plan on running near that boost on the street tho, probably more like 10-12lbs. definatley not that high until i have hondata.
let me know what you think or if there you know any one who has a similar setup.
