Tach Problem
Discussion in 'Civic and del Sol - EG and EK' started by seaninnis, Dec 28, 2008.
  1. seaninnis
    seaninnis New Member
    I have a 96 civic ex and the factory tachometer has no life. What should i look for? Check the wires in back of the gauge cluster and everything was fine. need some help thanks.
  2. 99sidude
    Ohio
    I do know that the tach signal wire is the baby blue wire on the drivers' side shock tower plug. See if you can borrow a testing tachometer to see if there is a signal. It could be a bad sensor in the dizzy, but I've never heard of that happening
