Tachometer wrong readings?
Discussion in 'Car Audio / Security / Electronic Accessories' started by hondakidd1, Feb 23, 2011.
  1. hondakidd1
    hondakidd1 HONDA 4 LIFE
    Chatsworth, ON, CaNaDa
    i just recently hooked up my aftermarket tach to the main dizzy, and i hooked it up with the battery and everything but i dont think its getting accurate readings (i dont think). wehn i start up the car and everything, and i rev it, the engine sounds like its redlining at about 4000 rpms? or thats what the tach says... it idles in between 0 and 1000, im not sure about this.
    Its a 1995 honda civic with a swapped acura integra B18B1
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Did you make sure the the tachometer is set for "4 cylinder"?
  3. hondakidd1
    how do i do that?
  4. hondafreak513
    hondafreak513 New Member
    O hi O
    Make sure the two small wires that are looped together sticking out are cut and taped up..
  5. E_SolSi
  6. Korax
    Korax New Member
    Western PA
    :withstupid:hahaha.
    Plus, you didn't need to do either of those. Maybe in an EG its easier to hook it up to the dizzy but your cluster should be wired for a tach even if it doesnt have one stock. You can splice it into that wire. Second, you shouldn't hook it straight up to your battery.. it will be drawing power even when the car is off...
  7. hondakidd1
    nah its nothing fancy doesnt even light up
