Tack, Need Help
Discussion in 'ECU's, Electronics, and Tuning' started by 22crazy, Feb 23, 2003.
  1. 22crazy
    22crazy Senior Member
    whats up i was just wondering how i hook up a tack....does it connect to the computer or something. like do u hook up wires to anything....if so if the signal like by pulse...analog, digital, voltage? thanx.
  2. BigJ
    I believe the tachometer connects to a wire near the distributor or coming off of it but I am not for sure. When we put a monster in my buddies just tapped into a distributor wire but I could be wrong. Someone correct meh if I am wrong.
  3. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    i hooked mine up to the blue wire near the firewall on the drivers side. but when i put in a stock guage cluster from an ex that already had the tach, i pulled out the aftermarket one. and one of them had to be wrong cause with my old guages the tach said i was revving to about 2100 rpm to go 30mph and with the stock tach it says i am revving a little over 1900 rpm to go 30mph. i don't know which is right but they both "worked". <_<
  4. sirkurtius
    sirkurtius Member
    toronto canada
    there should be four wires off your new tack.
    1 for power
    1 for ground
    1 for signal
    1 for lighting
    there should be a blue wire coming from your distributor so hook up there for the signal
  5. seerx
    seerx Member
    wires / color
    pos. / red
    neg. / black
    illumination / white
    tach signal / green
    loop wires/ i forget the colors but for a 4 cylnder u ussually have to cut both or the tach will be off the actuall rpm.if it way off then connect the (brown i think)wire back up. a crx si u have to tap the tach signal into the harness behind the tach in the cluster.i forgot the color(again)but it is the 2nd wire from the left when u r sitting in the car.for a 92-95 civic u go behind the cluster and look for a blue wire with silver dots.some dont have the silver dots. look in ur manul for the wire for other cars.or (this is kind risky)but take a test light and hook it up to a positive wire and than start up ur car.test the wires in the back of ur cluster when the wire barely lights up(by this time u must have the other 3 wires hooked up to ur new tach.) take the green wire and touch it to the wire that made ur test light light up.do it till ur tach works.
