Teg Ecu's, Is There A Difference?
Discussion in 'ECU's, Electronics, and Tuning' started by crxsi, Jan 16, 2003.
  1. crxsi
    crxsi Member
    ok, i have finally got my b18a and i was told i could use my stock crx si ecu. but i was also told that its controlled to where you cant rev over 7000. while if i use the stock teg ecu it is capable of 7500. first should i use the rex ecu and maybe chip it? or should i go with the stock teg ecu? if i go with the stock teg ecu is there a difference in the years 90-93?
    thanks
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    fuck chips unless you are getting something reprogrammable.. i.e. hondata, aem etc.
  3. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    yes. you need 90-91 teg ecu.
    90-91 = obd0
    92-93 = obd1
  4. crxsi
    crxsi Member
    ok i have to use the obdo ecu because my car is obdo, right? and what about my engine? its out of a 92 teg... and thats supposed to be obd1
    clarify exaclty what obd(0,1,2) is
  5. cxjon
    cxjon Senior Member
    man+k+toe
    your motor is an obd1... all i know about obds is that there smog stuff( im real smart ) i think you need to get an obd 1 euc and wire it up to work. i know there are people here that know how to do that and give more help
