INJEN78
HS LEGEND
anyone have a pic of how the timing belt tensioner is installed??
i forgot to check which hole the springs is supposed to be hooked on when i put my new one in.and just want to double check before i finish the job..
in case you dont know heres the tensioner.
also for the actual bolt in the middle of the tensioner,does the arch go toward the top or the bottom when mounted?
