my brakes have been losing pedel presser. I bleed them with out any change so im going to buy a remanufacted brake master cylinder from napa has anyone done this that could give me so advice or step by step instucthions. thank you
be sure to bench bleed the master cylinder before putting it in your car. clamp it in a vise, attach two foot-long lengths of tubing to the outputs, and feed them back in to the reservoir. then pump the piston several times so that fluid backs up into the MC through the outputs. In fact, you might try this before running to napa.
i have been bench bleeding the mc. the air just seems to be going into the lines and sucking back into the mc it seem like i cant get all the air out. thanks for the help
