Hi!
I'm all new to this forum, so hello to all of you.
I've a 93 civic as you call it DX. We call it LSi in Europe. It's a 1.5 dpfi (D15B2) equipped monster
Due to a strange idle problem i decided to swap dpfi to mpfi.
I used a d16a6 i/m with injectors and everything needed, pm6 ecu, td 02u distributor. I used the original mpfi injector harness to hook up the resistor box.
I made the wiring according to the writeups on the net, and I've checked in the service manuals too.
After I've finished everything: It won't start at all. Cranks, but there's no spark.
I started troubleshooting: checking wires infinte times, all OK
ignition modul inputs are all OK, so swap modul: nothing changed.
a professional checked the ignition coil it's OK, but for sure I changed it, nothing happened checked the other coil, he said the other one is good too.
ecu looks OK, cause the only code is No. 13 but EG civics does not have that sensor so, its all OK.
what happened? what else can I try to do?
Please help out with your comments, thanks a lot.
you can check the starting problem out on youtube: YouTube - civic
