Thermostat Lines
Accordturbo94
Hey does anyone know on the h's where the two lines go to on the thermostat housing! I know the one goes to the pump and the other the raditor... but it still has to small ports left in the top and the side... where do they go??
i think, if it's the housing on the back left corner of your engine, that they might be some sort of vacuum lines. just make sure that no fluid goes through the top 2. if i remember correctly there were two on the top that weren't for the radiator juice.
So not one person knows or has an h22 huh?? LOL Theres to 3 visable parts on the housing... one goes to the bottom of the radiator and the other to look about vacuum hose sized.. it may run the the bottomg of the throttle body!! any ideas?
