these cams
Discussion in 'Engine Building' started by ef9civicgen4, Mar 12, 2004.
  1. ef9civicgen4
    ef9civicgen4 Senior Member
    Independence MO
    Camshafts developed from Buddy Club's N1 endurance racing experience. Specifications: intake 304 duration, 11.59 mm lift, exhaust 294 duration, 10.71mm lift
    With these specs, what would these cams be good for. I dotn understand life and duration. Are these more or less aggressive than a CTR or ITR. Lastly would these be good for all motor, or Turbo Build Up's
  2. 97CTR
    97CTR Senior Member
    ctr cams
    11.5mm intake
    10.5mm exh
    278 and 280
  3. ef9civicgen4
    Independence MO
    so what does that mean?
    Low end power? Fucked up idle? Require upgraded valvetrain? or what?
  4. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    well they were developed for n1 racing from what you said in your post. probably not a cam for turbo charging but good for all motor to a point. those cams have been designed for road racing so they probably give you a good mid range and some high end. if your looking for an all motor cam to use the skunk2 might be a better choice if just want to make power. your going to need to upgrade your vavletrain if you want to take full advatage of a good set of cams unless you get ctr or a series 1 cam.
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    most of the spoon, buddyclub, etc.. from japan are developed with midrange in mind. Not necessarily top end which I am not sure is what you want?
  6. vtecsir1
    Orlando, FL
    what i was trying to get at thanks milan.
  7. 97CTR
    97CTR Senior Member
    lift and duration
    with an intake duration over 300 the idle will most likely be pretty bumpy
  8. JDMilan
    Boca Raton, FL
    yeah np,,,,,,,,
    Juns and Todas do very very nicely with I believe the Juns gaining the most on the top.
