redhatch92
Member
im doing my swap this week and i just wanted to make sure that everything will work. im putting this in a 92 civic cx 5 speed
From a 95 ls 5 speed: b18b1 engine with harness, flyweel, alternator, manifold with o2 and cat
From a 95 ls auto: distributor
From a 93 ls 5 speed: PR4 ecm
From a 00 Si 5 speed: Transmission, clutch, motor and trans mounts, starter, axles, jackshaft, shift linkage
Also will my radiator work properly with this swap or should i put an integra or del sol radiator
Thank you
Thank you
