Throttle Body Cooling
Discussion in 'General Tech and Maintenance' started by RFHOMI2U, Feb 11, 2003.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    My Cooling system is messed up, because i had used a A6 Intake manny, and a Z6 Block. i won't get into it. But My question is, is it completely neccessary to keep the Cooling part of the throttle body hooked up? Does It help that much? What happens if i don't cool it??
  2. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    Throttle Body cooling?
    The throttle body doesnt get cooled, one of the intake runners does on some engines. This is called the cold idle system. Not necessary.
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    false. there is a coolant line running through the honda throttle body.
    i would keep it there during the winter, but i took it off for the summer and per hondata dataloggin lowered my intake temps near 3* at 55 mph
  4. RFHOMI2U
    Thanks, I'll probably take it off then. I was just wondering if it was completely necessary. Only because I am having a little bit of a cooling problem. I am using the A6 intake, and The Z6 block, which has one more cooling hook up than the intake does. So now i have no outlet for the TB. Thanks a lot guys!
  5. pissedoffsol
    right on. if its winter/below 40 at a low where you live, run it. otherwise, its unnecessary
