Throttle cable
MRG719
I just bought i 91 civic hatch with b18a1 swap, do they make a shorter throttle cable mine seems way to long. Also need to see pics of clutch cable routing options mine is routed across the top and down looks like hell
you need a throttle cable from a 90-93 integra
not sure how your clutch cable is routed but there's really only one way to do it effectively so far as i can tell. you might be able to route it under the intake manifold but it would be a giant pain in the dick to accomplish due to all the wiring and hoses you'd have to navigate around. anyway, this is how mine's routed.
Sweet found one on ebay the dx throttle cable has worn a groove in my valve cover luckily not all the way through
