I've only done timing chains on Chevy and Ford V8 in the past.
So is this a job I should tackle myself or pay a shop to do it?
The CRX just turned 90,000 and it's time for some preventative maintenance. I figure while I'm at it I should do the water pump at the same time. Is it possible to do this maintenance at home in the driveway with your basic hand tools or are there some specialized tools needed to change the timing belt and water pump ??
I got a rough quote of $500 to do the timing belt, water pump and adjust valve lash, as I've never owned a car that has needed this type of service before I don't know if the price for this job is high / low etc....
Thanks in advance
Thanks in advance
