Timing ques
Discussion in 'General Tech and Maintenance' started by cheese9988, Jun 10, 2005.
  1. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    Quick ques, tuning up the crx with a dohc zc in it before I put it on the rd. I have heard advancing the timing can help sometimes. The motor is bone stock everything because I went for the stock look and sound. I don't think it will do anything much, opinions?
  2. brian11to1
    brian11to1 Senior Member
    I think you are right.
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    it all depends...
    turning the distributor can alter the timing, but the computer may see this and put in a retard correction t get it to fire at the "proper" time...
    try holding the throttle cable so the motor revs around 3000, then turn the distributor... find an ideal spot, then work the throttle back and forth and see if the motor spins up faster...
  4. pissedoffsol
    leave the dist. stock. if you want to mess with timing and tuning, look into turbo edit (yes it works on n/a cars)
