to welfare
Discussion in 'HYBRID -> EG-EK / DC' started by cx96gsr, Mar 26, 2009.
  1. cx96gsr
    cx96gsr New Member
    Hey welfare I know that you are a very inteligant honda guy. I need your help asap. Will a 99 civic si(b16a2) factory clutch fit in with the 94 integra gsr engine, flywheel, and transmission? Thanks in advance.
  2. cx96gsr
    cx96gsr New Member
    bump...
  3. eg6sir
    since this is for welfare, i suppose i wont answer your question then
  4. cx96gsr
    cx96gsr New Member
    bump...Anyone can answer if they know, I'm pretty sure 99% of the people here knows the answer.
  5. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    I wouldn't say 99% of the people know the answer.
    I believe it will, but I'm not 100% sure. You can probably find out by looking up good aftermarket clutch kit part numbers (that don't include flywheel) and if they match it should be fine.
    I know you cannot use a clutch kit for a hydraulic B series transmission setup onto a cable B series without changing the flywheel as well.
  6. cx96gsr
    cx96gsr New Member
    Thanks for the reply and help. Yeah i probably shouldn't had of said 99%, but I will try and do what you had suggested and see which way it leads me. Thanks again for your helpful reply.
