TOO LOW
Discussion in 'Wheels / Suspension / Tires / Brakes' started by racintweek, Mar 23, 2004.
  1. racintweek
    racintweek Senior Member
    Arlington VA
    :hmm: i have a 91 hatch just installed tokico blues and tein s-tech springs
    front of the car droppped damn near to the ground and the ass end didnt move
    (no the front springs arent in the rear and vice versa)
    what the hell is going on this is my daily driver and i need a way to get to and from work
    :bawling:
  2. UDT
    UDT Senior Member
    california
    Ive got no advice.......i just wanted to say that fuckin sucks lol..good luck man
  3. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
  4. racintweek
    Arlington VA
    im at work right now when i bring it in the shop later i will try to post some
    i work at a vw dealer so im goin to have one of the techs look at it after i get off
  5. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    are the upper mounts set in the perch right? sometimes the mounts can move (because the lower springs are shorter then stock) and when you let the car down, they can no seat in right, so the car sits higher then if the spring was in the upper perch right.
    thats all i can think of, unless they sent you the wrong rear springs...
    -Chris
  6. arpee79
    arpee79 Senior Member
    Maybe you put the front springs in the back and rear in the front .
  7. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    you might also want to let them sit in for a day or two if you are still stuck without an answer, when we put new springs on my buddies car, it took 2 or 3 days for the car to finally settle down to its new height.
  8. whiteLS
    whiteLS Senior Member
    Sarasota, Fl
    wow wtf i got those struts and i wave the same springs on the way
  9. racintweek
    Arlington VA
    :chair: yea im kicking myself the springs were swapped front to rear
    i'm a dumbass
    its fixed now
  10. E_SolSi
  11. pissedoffsol
  12. 90crxb18
    90crxb18 Senior Member
    lake elsinore cali
    hahahahaha!!!
  13. racintweek
    Arlington VA
    :moon: ok ok im bending over just make it quick!!!!!
  14. xkwzt21
    xkwzt21 Member
    thats some funny sh!t
  15. BlackFrog
  16. whiteLS
    Sarasota, Fl
    other than the flameing you just got how does the suspension feel now? do you like it?
  17. arpee79
    Yeah I told you so,been there done that,3 to 4 hours lost to the spring swap.
  18. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    I knew you had them on backwards as soon as I saw you say, "no the front springs arent in the rear and vice versa". LOL
  19. jamesA
    Since TPP hasn't been in here yet I'll go ahead and say it for him.
  20. racintweek
    Arlington VA
    car rides great it sticks in the turns and isnt harsh over bumps
    the front is a little high but will come down when ever i get the LS in there
    at least i didnt waste too much time i put my bushings in the rear control arms
    and got those in
