Too much Fuel B16
Discussion in 'HYBRID -> ED-EF / DA' started by VTECPOWER, Jun 22, 2005.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    My crx w/ b16 has waaaaaaaaaay to much fuel, how do i change this? a/f gauge is all the way at the top and spark plugs are black!
    EDIT: as far as i know, stock pw0 ecu from hmo.
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    get an adjustable fuel pressure regulator - yours is probably stuck and dumping all the fuel into the engine rather than returning some to the tank - we see this a lot on the JDM engines (or any engine, for that matter) that have been sitting for quite a while
  3. VTECPOWER
    Winchester, VA
    what is a good one to get and where can i find one at a reasonable price?
  4. ripperbone
    ripperbone angry bear
    Oklahoma
  5. VTECPOWER
    Winchester, VA
    so i will be able to regulate the amount of fuel going into my engine? thus turning it down?
  6. Cashizslick
    yeah but u dont wanna run lean - keep an eye on ur 02 sensor.
  7. VTECPOWER
    Winchester, VA
    At idle it runs all the way rich, but when i hit the gas it turns stoich. is this normal? Also i have a code 20 cel for the ground and still have no vtec. it's still in limp mode. rev limits at like 7400 rpm or so.
  8. VTECPOWER
    Winchester, VA
    Do you think my timing could be off? And how do i check it? Timing gun?
  9. formby
    formby learning in progress
    you need to fix all the bugs then you decide what to get....i believe that in limp mode the ecu make the engine run rich...and retards timing...but i'm not 100% sure..
  10. VTECPOWER
    Winchester, VA
    My point is that i don't even know what to fix, i have a code 20 which is electric load detector, not a biggie, doesnt effect vtec. But idk what else to try.
  11. VTECPOWER
    Winchester, VA
    Realized i needed a IAT sensor, mine is bad, thats why its in limp, but only place that has it is honda. and they cant get it for over another week.
