There is a pattern for each, so you dont warp it.
starting from 12 oclock and going clockwise, here is how you trq them
1,3,7,4,2,6,8,5 each trqed at 76ft lbs
for the PP.
the order is (same, start at 12 and go CW)
1,3,5,2,4,6 each at 19 ft lbs
If your getting an aftermaket flyweel, more then likely, it uses 9 pp bolts vs the stock 6. Thus you have to buy 3 bolts from honda at 3 a bolt (and that is if you show them the print out from Hparts, otherwise it is 4 a bolt)
Trannybolts, they are all diffrent, from about 30, up to 87. Buy your self a helms, They are the bible for honda.
