Toyota Owner In The Room
Discussion in 'HYBRID -> EG-EK / DC' started by zigy, Mar 13, 2003.
  1. zigy
    zigy Junior Member
    Chicago, IL
    Well guys I have recently aquired a '95 Honda Civic EX Coupe, I was planing to do 3SGTE
    swap in my '94 Celica but it was too costly... Right now I want to put a B16 in the CIVIC.
    I do know that I'm a Toyota freak, but I still do know some about honda engines. I have firmly
    decided that B16 is the one i want (not a B18 nor H22), so don't be saying don't do B16, but do this one...
    1. MY BIG QUESTION which B16 should I go with, .......... B16A2, B16A3 and etc..
    2. Second question is if $3,500 is reasonable rate for a proffesional shop to do the swap.
    This price includes "everything": B16, trans, labor, ecu, wires and etc.
    I live in Chicago area so there is not that many shops around here but 2-3 so there is not much
    competition going on...
    THANX A LOT FOR YOUR HELP, and I'll be seeing you around...
  2. beau_safken
    beau_safken Senior Member
    Seattle, Washington
    IF it was the B16A2 then yea that sounds reasonable. You would want that engine anyway due to it being OBD1 just like your car.
  3. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
  4. phunky.buddha
    Dallas / Fort Worth, TX
    B16A2 is OBD2, not OBD1. The B16A3 from the del Sol VTEC would be a good one to throw in- just make sure it's from a 93-95 del Sol. You can use the JDM Sir2 engine also- that's the 92-95 JDM B16 that works with your OBD1 system.
  5. beau_safken
    Seattle, Washington
    DOH!!!!!!! My bad...thank goodness there are others around to fix my screw ups...LOL
  6. phunky.buddha
    That's not what we're here for. Check your information before you go touting it as fact.
  7. beau_safken
    Seattle, Washington
    :kick:
    ......Me ... Calesta
    Yep I will have to learn to think twice type once... :)
  8. phunky.buddha
    Good. I'm not going to kick you in the nuts though. :lol:
  9. beau_safken
    Seattle, Washington
    I always kinda wanted to use that approach. :lol:
  10. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Just reiterating 95 civic = B16A siRII,94-95 delsol B16A3 :p
