TPS Code 7
ITR EG6
Member
I just finished my swap and I have a CEL. It scans as a code 7 "TP sensor signal voltage low". I tested it and I get 0.5v with the throttle closed and 4.5v WOT. It tests the same way at the pin in the ECU. Could this mean I need a now TPS? any help would be great. Thanks guys.
those are correct voltage readings, thats kinda mesed up why u got a CEL.. is it an old code?? does ur ecu store codes?
I figured it out, i had a bad connection at the ecu. I soldered a new pin on the wire and the light went out. Thanks for the reply.
