I'm having bogging issues at 5000rpms. I'm showing a code for the iat. My question is will that cause the bogging ? The car runs great otherwise, idleing, driving around but only when you want to get on it.
Are you guys having these issues after a swap? If so it could be that you guys didn't switch the 2 outer wires on tps sensor. Now if it's not it also could be your guys tps sensor mine did same thing, hope this helps good luck
