Tps removal and installation help
Rjs4490
can anyone give me some instuctions for removling my TPS and installing my new one that i just bought...I can see i just have to take out the two screws holding in the tps and just screw the new one on.. but im wondering if there is something else that i have to do...
My Car Info if needed :
93 honda civic vx hatch.
built lsvtec
95 b18b1 block
oem honda pr3 b16 pistons 11:5.1 comp.
oem honda piston rings
arp rod bolts
oem honda crank and rod bearings
type r oil pump
gsr water pump
gsr timing belt
oem honda headgasket.
hondata intake mani gasket
p30 b16 intake manifold
dc sports race header with 2.5 inch collector
2.5 inch exhaust with 2.5" vibrant muffler
golden eagle lsvtec kit
99 b16 head
supertech valve springs and retainers
gsr cams
gsr trans with act clutch
chipped p28 ecu
There is you, have to adjust the new one so that it reads 0.5 Volts when closed and 4.5 Volts at WOT.
