Tps Sensor Idle Fluctuating
Discussion in 'General Tech and Maintenance' started by thuy, Feb 13, 2003.
  1. thuy
    thuy Junior Member
    Does anybody know how to properly adjust the TPS sensor once new one is installed? I have problems with idling on my 91 CRX with ZC engine. I just got a new TPS sensor I want to try it out. Any help would be great.
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    yea, grind the rivets off the old one... put the new one in with screws... you can adjust it much like a distributor by rotating it left and right to change the voltage.... then use your hondata datalogging, or vafc to test for voltages.. make sure it is .5 volts closed and 4.5 volts WOT
    if you dont have hondata or a vafc or other means, use a volt meter.
