tps voltage wya too high
hybrid_b18
crew chief
whats up guys? its been a while but here we go. Ive got a 93 hatch with a 98 ls motor. 98 ls ecm, stock fuel pump(civic). my ecu has been throwing the tps and fuel supply codes. ive checked the tps and and at idle volts are 0.7. which is okay, but at WOT is 9.3 way too high. anyone know why that is and can you help?
also, the fuel supply code is because of the primary o2 sensor, right? but nothing should be wrong with my o2 sensor cause it only has 30k on it. anyone know whats going on there?
any help guys, thanks.
