90sihatch
OBD0 ls in a 90si. It's time to get this idle problem figured out, and I think I have it narrowed down. I've disassembled the iacv and fitv and cleaned them both with no results. I was messing around with it this weekend and I noticed when I unplug the tps the surging stops. With the sensor plugged in it doesn't throw any codes and obviously it does with it unplugged. So my question is, should adjusting my tps fix this or does it sound like I need a new one? And also, whats the easiest way to get the rivets out to adjust it? thanks
