90_EF_Hatch
Señor Member
Right now ...
I have a 90 civic hatch dx with a d16z6 with dc sport headers and a cat back exhaust (not sure what it is exactly, was on when i bought)
Ok so...
I have the transmission from a d16a6 on my z6. The reason is the tranny the z6 came with was hydrolic and my car is a cable setup. So my first question is should i convert my car to a hydrolic clutch and use the z6 transmission or does it not make much of a difference.
Also ...
I pretty much have decided to build me up a D series motor to put in my car because Im still learning alot and it is alot cheaper to fix/rebuild a d-series than a b-series. That being said, Should i build up my a6 block and put the z6 head on it (mini me) or just stick with the z6 block all together.
Finally ...
I dont make much money and i was wondering what the best rout to take would be when building my motor. I want the most for my money pretty much. I was thinking about $500 and i am was hoping to hit about 150hp (if possible for how much i want to spend).
Thanks for any help and if you see any probelms with what i want to do or have any advice for an alternative or what not just let me know. Im still learning .
Ok so...
Also ...
Finally ...
