tranny help
hb90racer
wasnt sure where to post this........ok i have a 1991 civic with the z6 motor. i have a 95 tranny sitting here would or should i say will it work if i take out the internals and swap them out so i can use the 91 tranny case and keep it cable? or would it be better to put the whole 95 tranny in the car and take a pedeal assembly from a 95 and bolt it up and run the hose to the tranny and stuff?someone please help car has been sitting for over 6 months now.... or if anyone has a tranny for sell let me know
91 internals will not fit in 95 case - converting the car to use hydraulic clutch is a lot of work - pedal is only part of the problem, as all of the mounts are different - you would be better off getting another cable transmission
