Tranny leaking
Discussion in 'General Tech and Maintenance' started by 90sihatch, Jul 3, 2006.
  1. 90sihatch
    90sihatch Senior Member
    I noticed a small puddle of oil in my garage a while ago and after some looking, realized there is a small crack in the casing of my tranny. It now leaks worse and I'm afraid it's going to get too low and the gears are going to get eaten. Is there any way like jb weld or anything to stop this leak, or am i screwed?
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i'd be a little more concerned about what caused the crack?
    you'll have a tough time getting anything to stick to the outside of the case...
    i would try roughing it up a bit with some sort of abrasive and then clean it really really well
  3. 90sihatch
    Ok, I took a closer look and the crack was just some grease. The fluid is actually coming out of where the axle goes into the transmission. Is there a broken piece inside or whats goin on?
  4. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Mine is leaking in the same place, i seated my axle wrong and i think i messed up the seal... we'll find out when i pull it apart, but it's probly that.
    (Did you recently change your axles?)
  5. 90sihatch
    I changed them when i did the swap
  6. VTECin5th
    Phoenix Az
    When was that done?
    (BTW, where did you get them, i need some)
  7. reckedracing
    NY
    prob inproperly installed or wrong sized axle seal...
    replace it, i doubt anything is broken besides the seal
    i would imagine you can get them from advance or autozone
  8. 90sihatch
    The swap was done about a year ago, but I had the axles out a couple of months ago. Do i just ask for an axle seal, or what do I need?
    I got mine from autozone
  9. reckedracing
    NY
    yea, ask for an axle seal...
    jack the car as high up on the side you are changing as you can and you prob won't lose any fluid...
